Detailing Discuss detailing your ride within.
musty mold smell-can't get rid of it
Old Oct 27, 2013 | 06:12 PM
dusty1's Avatar
Originally Posted by suzukisam967m
well no matter what smell solution you use you have to dry it first. Ozone will kill off any smells present long after the machine is removed. that is what fire/water damage companies use to kill the smoke and mold smell in houses that have burned then the fire department pumps them full of water..
Only if source of smell is removed.... Wet seat cushions or carpet or whatever. You are only scrubbing the air if source is still there... Smell is soon to follow.
Old Oct 27, 2013 | 08:15 PM
suzukisam967m's Avatar
that is true. I'm working on the assumption that he said he has already removed the wet carpet backing and everything. if the leather didn't actually get wet, which without submerging the vehicle I don't know how the seats could be wet?unless the sunroof leaked right on them. otherwise it's just dry spores floating around. and ozone will kill that. if the seats have actually gotten moist, you probably will not get the smell completely out.. once foam soaks it up you are screwed.. dry it out and kill it with ozone. thats the best you can do. otherwise call paul grant for new seat foam.
Old Oct 27, 2013 | 10:32 PM
dusty1's Avatar
I'm not trying to say you're wrong, at all. I'm only trying to say that I use these machines on a weekly basis and they do not work if the source has not been removed. the cubic amount of air inside a vehicle is tiny. He has been going for a week with his windows down. So it only makes sense that the source of the smell is still in the car. I am only warning not to spend your money renting a machine that will not work for the long-term. When I replace the burnt lumber, the charred aesthetics, and the wet insulation and the molded sheet rock and utilize one of these machines the smell goes away if I missed something the smell comes back.
Old Oct 28, 2013 | 10:57 AM
Your right. That's why I say if the seat foam got wet. . better call Paul grant
Old Oct 28, 2013 | 11:01 AM
dusty1's Avatar
that sounds like a spin off title of a spin off title "better call Paul"
bosalls5
LR2
Oct 21, 2016 06:39 AM
Chrisinhouston
Dec 4, 2015 08:12 AM
abran
May 28, 2014 01:09 PM
rovingmad
Aug 10, 2013 01:24 AM
