*HELP* Another won't start thread:(
Old Mar 11, 2014 | 11:24 AM
MAN "O" WAR's Avatar
Default *HELP* Another won't start thread:(
1995 Disco missed all of the snow fun this winter because it wouldn't start.
-Check engine light has never come on.
-It has fuel up to the fuel rail.
-It has spark. (used and in-line spark plug tester light thingy)
-It cranks but does not start.
- I kept the battery charged all winter. It never went dead etc.
-I decided to replace the fuel pump just because it has 100k and wanted to
do some preventative maintenance.
-fuel injector fuse is fine.
What led up to it not starting was when I was headed over to my parents
house it started wanting to die when at a light. Died once but I got it
started again pretty quick. Had a feeling of cutting out the rest of the way
to my parents house so I had to kept the revs up. Parked it there and
could start it as needed to move out of way etc but would take a lot of
cranking to get it started. Once it got cold out we couldn't get it started.
again.
Crank sensor perhaps? I'm trying to avoid calling a mechanic out to my
parents house but I'm close to doing it at this point. Not sure what a
mechanic cost in the Kansas City area for a house call? I'm not a "no it all"
type of guy so all comments and suggestions welcome
Thanks, Kurt from KC
Old Mar 11, 2014 | 06:14 PM
If you have a distributor you don't have a crank position sensor. If you have spark that is a good sign. Auto parts store will loan you a fuel pressure test gauge with a deposit. Attach to the Schrader valve on passenger side fuel rail (looks like a tire valve). When key is turned on the pump runs for a couple of seconds, should get to 32-34 PSI range. Could be clogged up fuel filter, among other things.
Old Mar 12, 2014 | 12:13 AM
Sorry, I forgot to mention that I replaced the fuel filter first. For some crazy reason
that I cannot comprehend, there is NO schrader valve!? Looked several times and
there isn't one anywhere on the fuel rail. I am familiar schrader valves because I
installed a fuel pressure gauge on my 93 Cobra years ago. Anyone ever heard of
schrader valveless Land Rover before?? I do know that the long block was replaced
before I picked my Disco up so they might of used an different fuel rail for some reason
perhaps? I'll try to get it started in a few day's after it warms up again and try some
starting fluid.
Thanks for the reply.
Old Mar 12, 2014 | 08:26 AM
wrongway1's Avatar
This sounds exactly like what happened with my 98. As odd as it sounded, I was told (sorry for whoever told me this, but I cannot find that thread to give them credit) to unplug the MAF, replace the plugs & it started right up. It ran like crap for a bit (till all of the fuel from cranking it was burned out of the exhaust) & then ran okay till the new MAF was shipped.
Old Mar 12, 2014 | 09:27 AM
tuercas viejas's Avatar
Test port for none tests port provided fuel rails.
Since the fuel filter is the same as Chevrolet approach Napa for a test port tool which substitutes the fuel filter for a hex shaped hollow bar shaped tool. Inserted where the fuel filter is located, the test port provided on the flank of the tool will allow you to read fuel pressure under test conditions.
That is the easy bit, now all you ahve to do is find the issue you are trying to fix!
T/V
ajnolin
Jul 2, 2015 05:22 PM
tophatQ
May 19, 2015 06:30 AM
toad2
Jan 17, 2014 09:19 PM
srockrae
Dec 6, 2013 08:28 AM
ATXDisco
Aug 1, 2011 09:47 PM
