[HELP] Coolant Drain Question
Old Dec 12, 2010 | 08:48 PM
calebbo's Avatar
Default [HELP] Coolant Drain Question
Which hose do I use to drain the coolant?
(bear with me with my DUH! questions)
So this is the coolant reservoir
(obviously don't use this to drain)
http://i944.photobucket.com/albums/a...o/IMG_0265.jpg
This is the left (facing the engine bay) of the radiator
<a href="http://s944.photobucket.com/albums/ad282/calebbo/?action=view&amp;current=IMG_0266.jpg" target="_blank"><img src="http://i944.photobucket.com/albums/ad282/calebbo/IMG_0266.jpg" border="0" alt="Photobucket"></a>
The hoses on the left of the radiator
(do I use these hoses?)
http://i944.photobucket.com/albums/a...o/IMG_0268.jpg
Hose on the bottom of the radiator [if you look straight down from the earlier pic] It's also connected to the coolant reservoir and somewhere else
(do I use this hose?)
http://i944.photobucket.com/albums/a...o/IMG_0269.jpg
The only hose I saw underneath the car near the radiator
(is this the one?)
<a href="http://s944.photobucket.com/albums/ad282/calebbo/?action=view&amp;current=IMG_0272.jpg" target="_blank"><img src="http://i944.photobucket.com/albums/ad282/calebbo/IMG_0272.jpg" border="0" alt="Photobucket"></a>
Old Dec 12, 2010 | 09:33 PM
antichrist's Avatar
If you need to empty it completely remove the expansion tank cap and disconnect the lower radiator hose.
If you're doing something like changing the thermostat and need to just lower the level remove the plastic plug on the left top (when you're facing it) of the radiator and siphon out some coolant.
When I had my radiator re-cored I had them install a drain-**** at the bottom of the tank on the left side of the car. Now it's easy to empty the cooling system without a mess.
Old Dec 12, 2010 | 09:56 PM
calebbo's Avatar
So picture 3?
Old Dec 12, 2010 | 11:14 PM
UpChuck's Avatar
Picture 4. It's that 2 inch or so line coming from the bottom of the radiator just above the frame. And when you pull the hose off, it dumps right onto the frame, and makes a big mess.
Old Dec 12, 2010 | 11:30 PM
calebbo's Avatar
Dang..
Any way NOT to make a mess? I love making messes..I hate the cleaning up though.
Old Dec 13, 2010 | 03:06 AM
Long Haul's Avatar
Originally Posted by calebbo
Dang..
The only way I know how to not make a mess is to cut a hole in the hose but that only works if your gonna replace the hose. You can try loosening the clamp up and slowly let it drip out other than that hope you have plenty of floor dry or a really big catch pan.
Old Dec 13, 2010 | 05:51 AM
antichrist's Avatar
Siphon out most of the coolant through the plug in the radiator.
You really need to shrink your photos...too big and too long to load. I don't even look at them.
Old Dec 13, 2010 | 07:04 AM
calebbo's Avatar
Thanks, I guess I'll just cover the floor with plastic bags or something. Haha
Thanks, will do.
Old Dec 13, 2010 | 05:16 PM
Covering the floor with plastic bags will only make a bigger mess.
Old Dec 13, 2010 | 09:34 PM
calebbo's Avatar
I was just kidding, I just did it over grass and had a bucket underneath. Still a little messy, but not as bad as it could have been.
myall200
Dec 18, 2012 12:04 PM
ToddD
Jun 26, 2012 06:58 AM
bcolins
May 9, 2011 02:27 PM
focusontheworld
Nov 13, 2007 10:26 AM
werldcup
Mar 23, 2007 11:13 PM
