[How To] Replaced Power Steering Fluid
Old Dec 13, 2010 | 07:10 AM
calebbo's Avatar
Oh yeah, didn't the shop you used top off with PS fluid? How did that go when you called to ask if they would cover repairs?
Old Dec 13, 2010 | 07:11 AM
ngarover's Avatar
I'll know today after I speak with them. This is a small town, small shop, and was an honest mistake. I would be happy if they simply put the new one on for me. I don't expect them to replace a PS pump with almost 200k on it with a new one. I'll buy the part.
Old Dec 13, 2010 | 08:11 AM
calebbo's Avatar
Sounds reasonable, good luck. Hopefully you don't have jerk mechanics where you're at.
Old Dec 13, 2010 | 05:21 PM
Just so you know, the bleed screw is ontop of the steering box.
Old Dec 13, 2010 | 05:23 PM
ngarover's Avatar
They agree that they bear some of the responsibility for the damage and are going to do the labor at a great discount. I'm going to put a chevy version back in since new they are only 80 bucks, they will take care of doing any modifications etc total cost 100 bucks. I felt that was fair.
Old Dec 13, 2010 | 06:10 PM
Chris-bob's Avatar
I like that shop already.
Old Dec 13, 2010 | 09:16 PM
calebbo's Avatar
Oh, see I didn't know that. I thought it was one of the hoses coming from the reservoir.
Old Dec 14, 2010 | 08:42 PM
AuZZZie's Avatar
Ok so the correct procedure is..
Attach hose to bleed screw (anyone know tubing size?)
Crack the bleed screw
Start vehicle to get the pump running
Make sure to keep the reservoir topped up (how quick will it drain? Is this a two man job?).
People were quick to put down the OP's method but didn't exactly clarify on the correct way.
Old Dec 14, 2010 | 08:46 PM
Yes that is the correct way.
Ice maker water tubing from The Home Depot.
Yes you will need a helper and a empty washer solvent bottle.
Depends on how far you open the bleed screw.
Old Mar 28, 2021 | 12:13 PM
archaeology_student's Avatar
Silly question, but where is the bleed screw located?
*** update ****
Finally found it under the section
Power Steering System - Bleed
Service repair no. - 57.15.02
DakotaTravler
Jul 24, 2025 08:40 PM
Jabez
Feb 6, 2012 02:56 PM
aarongregor
Jan 4, 2012 06:04 AM
RedAustinIX
May 25, 2011 02:20 PM
eandrews2
Aug 4, 2008 04:02 PM
