1994 Disco..crank but no start
Old Aug 15, 2013 | 01:20 AM
  #21
Josh Barlow's Avatar
38 psi..checked with tire gauge ,thank u great idea..tested injectors with test light and watched it pulse..did find a bad connection to the engine temp sensor..corroded connectors..possible bad sensor too..I just bought a new battery.
Old Aug 15, 2013 | 01:26 AM
  #22
Maybe it is a fuel temp sensor..gotta verify
Old Aug 15, 2013 | 07:53 AM
  #23
This Rover booklet shows the values of the various sensors for different fuel injection systems. Also check for shorted or grounded wire from sensor.
File Type: pdf
Old Mar 18, 2021 | 09:16 AM
  #24
scwholesale1's Avatar
Default I’m having similar issues
Except I had a shotgun sounding noise come out my tail pipe and it was running very rough very bad idle, they have checked the mass airflow sensor they have checked all kinds of things one guy is trying to tell me who is not a mechanic that I have jump the timing chain, whatever that means but anyway he couldn’t tell me for sure he said so I don’t know what’s going on but it runs rough now it will not crank it out no matter what I do, I’ve unplugged the mass airflow sensor and somebody told me that would tell me whether that was the issue . So there’s no need for me to put that mass airflow sensor of the new one that I bought on there right? If I unplugged it and it’s still not working. Somebody please help me I’m desperate here I’m stranded
It’s a 2002 disco II SD
There is no BCM on a D1. So a spark plug attached to spark plug cable shows nothing when cranking? The engine is turning over, just not firing?
Mesure fuel pressure on passenger side fuel rail. Should be 32-34 PSI. Test port looks like a tire valve.
Bad ECU unlikely.
Bad crank sensor and it won't crank (on the GEMS engines).
Bad ignition module, if you have a distributor, can heat up and die off.
Greether
Apr 22, 2012 09:18 AM
billyw
Nov 24, 2011 10:33 AM
vin1124
May 12, 2011 10:57 PM
timothyfuqua
May 30, 2009 08:35 PM
DiscoGal
Oct 17, 2006 03:36 PM
