1995 Discovery Losing Oil
Hello!
I've got a 1995 Discovery, I've got a problem with the oil, it seems to be disappearing but not leaking or being burnt...
There is no smoke at all from the exhaust, when driving, revving or idling, there is also no leaks at all underneath. But the Engine oil only lasts about 2 days and it's gone, I checked it on Friday and it was empty, nothing on the stick, I filled it to the FULL mark, Again, no smoke or oil smell, or leaks... and today (Sunday) it is once again almost empty, so far it has done almost 6 Liters in 2 days.
The Turbo was my suspect, but it seems alright, only a small amount of oil in the intercooler pipe, but if it was letting 5L on oil through the Turbo, it would smoke like hell. So the oil has got to be going somewhere but where?
Can anyone throw some light on this situation please?
re: there is also no leaks at all underneath
Because it is empty.... Any oil spots on back glass or bumper, it might be blown out whilst motoring and not whilst parked. Dunno about the diesels but the V8s have an oil cooler that runs thru the radiator.
If nothing is dripping on the ground then there are only 2 possible answers, your engine is burning it or it is leaking into the coolant system. If it is not in the coolant then I would start with a compression test, possibly both wet on dry and if need be a leak down test.
I've been told by a few people today, that if the type of Engine oil used has changed, the engine some how soaks it up, then you have to top it up, is this something you have heard of?
I'm new to landrovers but not to Engines, and I've never had this happen before where my Engines have Soaked the oil up into gaskets etc...
Mmm, the Coolant is oil free, and that doesn't go up or down.
Not six liters in two days. That's almost an oil change. But who knows, surely by now it will have soaked up all it can. Oil leaks, like coolant leaks, are not always when parked. They can be dripped off and usually make spots or grime on the back hatch or bumper. Plus if you have brand new synthetic oil, it can be so colorless that it is hard to see even on the stick, and hard to see where a leak is around a gasket.
Or you could have an evil "friend" who is sneaking over to drain some each night.
Diesel or petrol?
If you switched oil brands it is common for the engine seals to "soak up" the new motor oil, once the seals get filled with the new oil it will stop.
This has happened to me more than once on many different cars.
Not as fast as yours is doing it, but still happened.
