1995 Discovery still no spark after 6 months
Ahhh of course, and that answers my other inward question about "what about the distributor".
I am beginning to distrust the distributor (in fact the pick-up coil inside even though it tests o.k. regarding resistance).
It surely is maddening and getting expensive with zero success to not be able to get a spark out of the ignition coil at all.
D.U.I -Davis Unified Ignition = one 12V wire hookup and brand spanking new distributor! Do you want me to hold your hand and take you to the site personally? Performance Distributors « Performance Distributors
For the life of me I cannot understand what you do not understand.......... I've tried.
Even if that where true Tom he still has an ongoing issue with sparks that's lasted a long, long time now. Must get past that little problem first. The alarm can be reset anytime.......
Hey buddy, I understand that, and thanks again. It is on order.
I should be running ahead of myself.
My vote is the Mallory unilight. Or the MSD system mentioned above. At least you know you are getting a relatively bolt in item. Although the one wire install of the HEI is nice.
Let's see, Colorado yard art or a simple fix and a reliably running vehicle for the long term.........$700 is peanuts. Now to figure out where the white wire comes from and goes to.....that has me concerned. I don't own a dizzy equipped truck I can poke around and there's nothing in the Rave about it other than ignition switch circuit. The location is far from what's in the Rave, wrong side of vehicle.
