1996 discovery - did not pass smog :(
Old Jan 17, 2011 | 07:13 PM
yvonne67's Avatar
Question 1996 discovery - did not pass smog :(
Hi to all Again and Happy New Year!
I took my 1996 discovery to have it smog, and to my surprise it failed
I was told it read high emission Co, almost 9%, can some explain to me, what does this mean, and how can I fix it?
Wisdom help is greatly appreciated.
Thanks,
Yvonne67
148,000 miles
Old Jan 17, 2011 | 08:19 PM
Is the check engine light on?
If not I would suspect the catalytic converters are bad.
You can have them replaced with universal ones at any muffler shop.
They will take out your old ones and weld in new ones.
Expect to pay around $100 each for parts and labor, you have two of them, one for each side of the engine.
If you look under the middle of the truck you will see a pipe coming from the engine in the shape of a "Y", on it you will see to big round things.
Those are your "cat's."
http://www.autozone.com/autozone/par...2_64164_15704_
Here is what the "Y" pipe looks like with the cats.
http://www.autozone.com/autozone/par...0_64164_15703_
Old Jan 17, 2011 | 08:42 PM
yvonne67's Avatar
My light engine is not on..... thanks for response and the pictures, I will take it to the muffler shop on Wednesday.
have a great evening.
Yvonne67
Old Jan 18, 2011 | 02:59 PM
Before you wonder off to a muffler shop, what about your engine, when was it last tuned along with new plug wires, what octane gas are you burning?
Old Jan 18, 2011 | 04:01 PM
yvonne67's Avatar
Hi Mike,
The last tune up was done on early November 10. Including new wire on the plugs. Regarding gas, I'm using 89 Octane, once now and then I'll fill up with the highest.
I friend of mine who know a little Mechanic came in today and had a quick glance, he mention that the accelerator valve is not working properly, that it should be replaced.
Can this be correct?
I called several muffler shops, and the cheapest quote is of $230.00, including parts and labors. Does it sound right?
Another question, I am cash tied at the moment, If I was to sold my Discovery without fixing the above issues, how much could I ask for it?? Other than the above it's been working great. Cosmetic wise it's in fair condition, inside/out.
Thanks,
Yvonne67
Old Jan 18, 2011 | 06:54 PM
$230 for both cats is a fair price.
If you sell it just let the buyer know what it needs and if they offer you less and you are ok with that then take it.
www.kbb.com
www.edmunds.com
www.nada.com
Use those sites to determine the value of your truck.
As far as the "accelerator valve" not working, I have no idea what that is.
Did he say it was the throttle body not working correctly?
If you friend is a mechanic and has a welder he can replace the cats for you, you buy them and he welds them in for the price of a pizza and beer.
Your throttle body can be cleaned.
Old Jan 18, 2011 | 07:25 PM
yvonne67's Avatar
I apologize for my poor english, I was explain that this valves controls the speed of the car, hope this help, I'll ask the exact translation and let you know latter.
Thanks for links, very helpful!
Old Jan 18, 2011 | 08:05 PM
I am going to assume he means the throttle body.
If you look in the tech section you will see how to clean it.
Have him do that.
Do not replace it, just clean it.
Old Jan 19, 2011 | 08:47 AM
www.kbb.com
www.edmunds.com
www.nada.com
I would suggest you hold off on replacing your cats, since you don't have a fault code and it has not yet been proven that they are bad.
You need to find a good shop that can diagnois this problem using a scope and an exhaust analizer.
Let us know what they find.
tcjx4
Mar 3, 2013 03:22 PM
Silver_Slug
Jul 18, 2010 09:30 PM
Street Wolf
Off Topic
Feb 15, 2009 12:19 PM
sfxgamer
Aug 17, 2007 09:05 AM
evoasis
Nov 17, 2006 10:31 PM
