1998 Disco Ball Joint / Tie Rod End
Have some one move you're steering wheel left to right about a quater turn. Watch the rod ends, there should be no play/slop between the body and shank of the ball joint.
The stabilizer bar mounts with a stud and nut at each end, so it will be able to be spun it it's mounts.
The steering box has a 19mm nut with a torx screw in the middle of it, right on top of the box. Put a torx driver on the screw to keep it from turning, loosen 19mm jam nut, tighten torx screw snug but not overly tight, the tighten up the jam nut. Drive, repeat as needed to remove play from box.
Thanks. I tried to tighten the steering gear box and must have tightened it a little too much. The steering felt very weird so I backed it off and it seems fine. I will have some one turn the wheel while I check the play as you said. There is a bad shaking sensation when I hit a bump and I basically have to slow down quickly to get it to stop. From what I understand and from responses from a post of mine years ago, That could be caused by a number of things. It may be time to take it to a Pro.
Sounds like something someone was jug covering recently in a thread. Swivel pin pre-load? Causes what everyone who's experienced them calls "death wobbles". I'm pretty sure that's the likely culprit. I think every one adjusts the preload in conjunction with doing the swivel pin bearings. I could be wrong. I think bad swivel pin bearings can cause death wobbles right?
Usually death wobble on these trucks is either swivel pin preload or panhard rod bushings. Tie rod ends can cause it to but usually if they are bad the truck will just wonder all over the road. Also check the pitman arm nut(connects to the steering box), i just bought a 96 and the nut just was about to fall off of it causing some very bad steering issues. Easiest way of checking things like said before, have someone move the steering wheel while you inspect every joint for movement.
me 2
06-13-2013 03:26 PM
