1999 Discovery I SD Cuts out in Traffic/at Stop Light/at rolling stop/when A/C is on
Old Nov 9, 2014 | 04:59 PM
colemtd's Avatar
Default 1999 Discovery I SD Cuts out in Traffic/at Stop Light/at rolling stop/when A/C is on
Any ideas?
If I am in a fast food drive-through line I can feel the engine getting rough and starting to shake and then I have to throw the gear into Neutral to calm it down otherwise it will cutout but it always starts right back up.
If I have my A/C on it will cutout as well if I am in traffic or at a stoplight.
If I coast into my garage it will cutout sometimes once I take my foot off the pedal to let it coast into the driveway and into the garage.
All of these issues don't happen all the time just often enough to be embarrassing and annoying at the same time!
Any ideas?
Old Nov 9, 2014 | 07:15 PM
TOM R's Avatar
check the pcv hoses,clean the pcv noodle, clean the iacv and throttle body, you should get an ultra gauge to see whats going on
could have lumped all these threads into one
Old Nov 9, 2014 | 08:19 PM
or having just looked at the other thread something is wrong inside the tranny and it's dragging the engine down.
Old Nov 10, 2014 | 01:01 PM
colemtd's Avatar
Thanks, I will get my mechanic to help me figure out what you just said... LOL!! ;-)
Old Nov 10, 2014 | 01:03 PM
colemtd's Avatar
Thanks so much, I will look into all of this and report back. And yes that's very observant of you because my transmission is giving me problems as well... I can be driving and it starts to drag all of a sudden and then mysteriously picks up speed again, but that's another post for another time!
Thanks All..
Old Nov 10, 2014 | 01:52 PM
nuclearw's Avatar
Thanks All..
This sounds like a bad VSS .... I replaced the tranny before finding out that was the cause.
As your driving usually between 45-55 (maybe higher) the engine all of a sudden cuts back from 2500-3k down to ~1800?
If you have an OBD2 Reader (cheap bluetooth, or ultragauge) check the vehicle speed. If the VSS Fails it will report to the engine much higher speed than your actually travelling. the Speedo will read fine however adding to the confusion.
VSS is easy to rebuild, there is a thread on it in the tech section.
not sure if it would account for the stalling in traffic but you never know ... if it is really hosed
Old Nov 10, 2014 | 02:12 PM
TOM R's Avatar
if you suspect the vss just unplug it, you will lose the speedo but drive it and see if something changes, its on the transmission left side by the big brake drum
Old Nov 14, 2014 | 01:17 AM
colemtd's Avatar
Thanks, you guys are awesome, I see I have a steep learning curve but I will let all of this digest and see what needs to be done.
Old Nov 14, 2014 | 01:20 AM
colemtd's Avatar
Tom! You are SPOT ON!!! Whenever it drags I DO lose my speedometer function!!!!
Then I have to depend on my GPS speedometer to tell me how fast I am going.
That was another problem that I was going to post on here but you called it already.
So what does this all mean? I guess I need to replace this VSS thingy??
Old Nov 14, 2014 | 07:34 AM
TOM R's Avatar
Vss is vehicle speed sensor, go in the tech section there are directions to rebuild it, for now I would unplug it see if you get a change
