1999 discovery1 antilock module
Somewhere here I was following a thread quite a while back. someone told of a bleeding procedure at the lines on the antilock module that worked. I had to replace the booster and now need to clear the code on this item. Does anyone remember where I could find that discussion again or know the procedure I need to bleed the lines at the antilock module? Thank you.
I should clarify I don't believe my issue is properly described as a code, it is the antilock warning light.
The procedure I am looking for is a basic procedure of bleeding the lines at the ABS module while brake is engaged, steps taken in the right order that result in clearing the warning light and returning proper function without the need for special equipment.
Mecevans
Aug 9, 2015 02:30 PM
srfnsno99
Aug 26, 2011 11:25 AM
