3.9 V8 Tachometer and Squealing Issue
Old Apr 18, 2022 | 10:58 AM
LipLounge's Avatar
Default 3.9 V8 Tachometer and Squealing Issue
So squealing will get louder with engine speed. And the tachometer will not respond while it’s squealing. Then when the squealing stops, tachometer will kick on. The two issues are completely synchronized.
So I’m guessing alternator (original) related. Perhaps the pulley? Seems like the pulley is spinning freely and not turning the alternator.
Not having any battery issues yet.
Thanks in advance.
Old Apr 18, 2022 | 12:00 PM
94Disco1's Avatar
Alternator related would be my guess as well, although I've never heard an alternator "squeal" as you describe. Imagine if you pop the hood and visualize the alternator pulley would be able to tell if it was spinning?
I've found a good pair of mechanics ears/stethoscope to be invaluable in diagnosing serpentine related noises (and all kinds of noises...).
If it is the alternator I'd avoid any long trips before you get it sorted out...
Old Apr 18, 2022 | 11:38 PM
JohnZo's Avatar
There's a small wire out the back of the alternator that provides the signal to the tachometer. If the belt slips on the alternator pulley, it will squeal. There is extra force at the alternator pulley right after starting as the battery gets recharged, especially if the battery is on it's way out.
Parts stores have pretty good free tests to check batteries and alternators. That's where I would go.
redwhitekat
Aug 11, 2021 06:36 AM
dtbcnstructin
Jul 8, 2014 09:11 PM
humroot
Feb 28, 2013 10:58 AM
awer25
May 3, 2010 12:41 PM
evoasis
Nov 2, 2006 03:57 AM
