300 tdi dies under load
Old Jun 10, 2017 | 09:54 AM
keyesjosh's Avatar
4wd High
Default 4.0 dies under load
1998 Disco..
Starts, idles and runs great until..
When out four wheeling or climbing and under heavy load it dies. Restarts no problem. However whenever under a load it will die before I can get wheels to spin only when climbing or stress on motor. Fuel issue under heavy load or air problem?
Old Jun 10, 2017 | 03:26 PM
DiscoCam's Avatar
Originally Posted by keyesjosh
1998 Disco..
Have you recently changed the fuel filter? Should be done every oil change on a 300tdi from my understanding because they can cause a multitude of problems if neglected.
Old Jun 10, 2017 | 03:38 PM
keyesjosh's Avatar
4wd High
Think filter could cause that? I guess Im throttling pretty good to get the torque I need. Will change filter this week. I have one ready to change but didnt think that could cause it. Thanks
Old Jun 10, 2017 | 04:45 PM
DiscoCam's Avatar
300tdi is a fairly simple diesel engine. Wouldn't be surprised if the fuel filter causes it. It's a maintenance item anyway, so might as well try it.
Side note: There's a youtube channel called Land Rover Toolbox Videos. They have pretty much covered everything there is on the 200tdi and 300tdi so you should check them out. They also do TD5 stuff too.
dirkha
Feb 10, 2021 06:44 AM
shampro
Audio/Visual Electronics
Aug 23, 2009 09:21 PM
sesese
Aug 9, 2009 02:23 PM
teletechlpi
Nov 6, 2006 09:04 PM
landyrangie
Dec 22, 2005 06:09 PM
