4.0 and 3.9
Old Aug 4, 2019 | 09:16 PM
Sempervincens13's Avatar
Default 4.0 to a 3.9. Possible or not worth it?
Hello,
My first post, and hello to everyone. I tried searching for this topic as I don’t want to contribute to redundant post, no luck. I’ve seen post about guys wanting to upgrade from a 3.9 to a 4.0 but nothing about anyone using a 3.9 in a 4.0........So here is my question::
I’ve been on the search for a ‘97 disco or just a GEM 4.0 to replace mine that has a slipped sleeve... no luck that makes any financial sense. Yesterday I came across a ‘94 defender 3.9 (not confirmed, haven’t looked at the vin yet) for $140 that according to the owner, he pulled because he changed everything to diesel, engine ran fine before being removed. I bought it with the thought of if it doesn’t work for my application, I’ll recoup my money easily.
Reading about it, it seems that the 3.9 doesn’t have a few sensors the. 4.0 does. If I were to go ahead and have the machine shop pull it apart and add these sensor areas (if possible) along with doing the crowned liners and trick items (Crowley cams, etc).... would this shoe into my disco or should I continue looking for a 4.0? Thanks in advance!
Last edited by Sempervincens13; Aug 4, 2019 at 09:22 PM. Reason: Title was too vague
Old Aug 4, 2019 | 09:51 PM
It will take some work to convert the electronic, but the 3.9 will bolt up no issue.
Defender, RRC or Disco 1 3.9 were all basically the same
Old Aug 5, 2019 | 12:30 PM
fishEH's Avatar
You should be able to combine parts to make a good 4.0. Front cover and intake/plenum from the 4.0 with the 3.9 block.
*** Listen to Robert, he knows WAY more than me!!!
Old Aug 5, 2019 | 01:06 PM
robertf's Avatar
Theres no crank sensor hole or knock sensor mounts
the defender 3.9 will be serpentine belt so the crank key wont be long enough for the 4.0 cover
Old Aug 9, 2019 | 10:17 AM
Paul Grant's Avatar
Way easier to take a 4.0L back to a 14CU configuration that it is to cut up a 3.9L block to accept a crank sensor and NOx sensors for GEMS. I would not recommend most people try this sort of thing. Maybe take it to a machine shop but I find it hard to believe a DI 4.0L is that hard to find real cheap.
Old Sep 6, 2019 | 06:30 PM
Edgardo Santiago's Avatar
I did it changing to carburator with a buick intake manifold.
Old Sep 6, 2019 | 06:49 PM
fishEH's Avatar
If you're replacing sleeves in the 3.9, why wouldn't you just replace them in the 4.0 you have?
2Guinness
Engine & Internal
Sep 23, 2018 10:22 AM
topraamen
Jun 1, 2017 01:30 AM
Southern
May 9, 2017 06:36 AM
Shiftonthefly1
Jul 8, 2015 03:10 PM
RoverPower
Mar 25, 2015 09:40 AM
