Sponsored by: CARiD
3.9 vs 4.0
Old Jun 30, 2015 | 12:31 PM
Shiftonthefly1's Avatar
Default 3.9 vs 4.0
I'd like to rebuild the engine from my parts truck and use it in the new to me 97 Disco. Since its free and sitting there.
I'm wondering if I can adapt the 3.9 long block in my 89 Range Rover to work with the 4.0 systems and accessories. I have a later model timing cover w the distributor delete. Are the basic foundations the same?
What about doing the 4.6 crank in the 3.9 block? I've read in a couple forums that the 3.9 has a narrower main bearing than the 4.0. True?
Old Jun 30, 2015 | 08:06 PM
FantomRover's Avatar
Im interested as well, I also have a Rrc parts truck and it's got a low mile 3.9 in it.
Old Jul 1, 2015 | 05:43 AM
drowssap's Avatar
you will have trouble with the crank, "i" believe the 4.0 crank is longer than the 3.9 in order to drive the new style oil pump.
also the mains are a different size 2.0 on the 3.9 vs the 4.0 with is 2.185, nothing that line boring the block wouldn't fix, but i don't "think" the block can be clearanced enough to run the throw on the 4.6 crank.
But you could build a killer 4.2 to put in there, i would assume 4.2 cranks and rods can be had cheaply.
Old Jul 1, 2015 | 09:49 AM
dusty1's Avatar
info
Buick 215 Rover 3.5 Land Rover 4.0 and 4.6 differences
File Type: docx
Old Jul 1, 2015 | 10:02 AM
Paul Grant's Avatar
Drilling the two small holes for the knock sensors would be enough to make me rethink using a 3.9L but that VERY specific hole for the crank sensor is even more frightening.
Old Jul 1, 2015 | 01:12 PM
Damn. Ok. I'll source a 4.0. Thanks for the info guys.
Old Jul 1, 2015 | 01:15 PM
dusty1's Avatar
Old Jul 1, 2015 | 01:28 PM
I hate you. Get yours running already!
Old Jul 4, 2015 | 12:35 PM
ihscouts's Avatar
How did you end up with another Disco Shifty? I missed the whole enchilada on that. Your still keeping the RRC yes?
Old Jul 4, 2015 | 01:20 PM
It hurts me when you don't pay attention to my life! You never listen to me any more!
I had to sell. There is a thread explaining it in the off topic room.
