95 disco 1 not starting up
was running okay till i parked it at a local restraunt to eat. when the meal was over and was trying to go home and it started and stalled before i could get out of the parking lot. would not start up since.
new items:
fuel pump
ignition coil
plugs
wires
dist cap
dist rotor
had to fix the dist the little springs on the bottom came loose and thought this was the problem for sure but still no luck starting it up
checked timing
6 degrees on marker #1 at tdc and dist rotor pointed at #1 point on the cap.
I have spark coming from the coil and i can smell fuel out of the tail pipe so im curious on what else it could be. Any help and leads would be helpfull thanks.
new items:
fuel pump
ignition coil
plugs
wires
dist cap
dist rotor
checked timing
Can you hear the pump running? Verify that its actually running. If its not it could be the fuel harness plug. Mine was bad and it caused intermittent no-starts, cut-outs, and even threw 4 codes including 2 misfires. Swapped out the harness from the fuel pump to the wheel well and I've been good to go. Try jiggling the plug quickly(you only have a few seconds) after turning the key to ACC, if the pump isnt running.
95GreenDisco
12-04-2008 09:32 PM
