95 disco 1 not starting up
Old Aug 13, 2011 | 12:04 PM
yoshi_hito's Avatar
3rd Gear
Default 95 disco 1 not starting up
was running okay till i parked it at a local restraunt to eat. when the meal was over and was trying to go home and it started and stalled before i could get out of the parking lot. would not start up since.
new items:
fuel pump
ignition coil
plugs
wires
dist cap
dist rotor
had to fix the dist the little springs on the bottom came loose and thought this was the problem for sure but still no luck starting it up
checked timing
6 degrees on marker #1 at tdc and dist rotor pointed at #1 point on the cap.
I have spark coming from the coil and i can smell fuel out of the tail pipe so im curious on what else it could be. Any help and leads would be helpfull thanks.
Old Aug 13, 2011 | 05:50 PM
antichrist's Avatar
Have you verified all the plug wires are routed correctly, and number 1 is at number 1 on the distributor?
Are the plugs gaped correctly?
Do you have spark at the plugs?
Old Aug 13, 2011 | 08:22 PM
adigerol77's Avatar
Is it cranking at all? You said you smell fuel at the tail pipe. I'm assuming that's while cranking? You're not firing.
Old Aug 13, 2011 | 11:45 PM
yoshi_hito's Avatar
3rd Gear
Correct anti I checked for spark at the coil then at one of the spark plugs and both getting spark. Have not checked the fuel pressure yet but iirc it should be around 2bars
Old Aug 15, 2011 | 06:22 PM
demonlarry's Avatar
check the vacuum advance on the distributor. if the diaphragm is bad, you 'll have a pretty good vacuum leak, and the distributor will not advance/retard like it should.
Old Aug 16, 2011 | 11:53 AM
fishEH's Avatar
Can you hear the pump running? Verify that its actually running. If its not it could be the fuel harness plug. Mine was bad and it caused intermittent no-starts, cut-outs, and even threw 4 codes including 2 misfires. Swapped out the harness from the fuel pump to the wheel well and I've been good to go. Try jiggling the plug quickly(you only have a few seconds) after turning the key to ACC, if the pump isnt running.
lazerbrains
LR2
38
Aug 9, 2023 07:54 PM
primecooler
May 5, 2009 03:53 AM
dragon_avaloch
Nov 15, 2008 07:35 AM
pants
Oct 19, 2005 12:47 AM
