95 Disco slumped stance
My 95 Disco appears to be slumped in the front-right area when parked on a flat, or any other surface. New 2" Terrafirma springs/shocks all around and as far as I can tell front shock towers are not degraded in any way, haven't been able to get under it to inspect springs/shocks thoroughly but on quick inspection couldn't see anything obviously wrong. Any ideas?
Thanks FishEH, yeah, I know that they are left/right side specific. Install was done at my local shop and I did tell them but....well, you know. I'll look for markings when I next get under it. Failing that, think I'm still within the 1-year warranty period so if something has failed at least it can be replaced.
Finally getting back to this. Had it up on the lift and after some poking around found a faint printed D/S on the driver side spring - so I assume they were installed correctly. I got a different measurement on each wheel when on flat ground...So, safe to assume the spring might be buggered?
