95 discovery... are aftermarket rims possible at all?
Old Mar 7, 2013 | 01:53 PM
disco360's Avatar
Default 95 discovery... are aftermarket rims possible at all?
I have a 95 disco and I am dying to put rims on it... how can I do such due to the fact that the pattern is supposedly "exclusive"
Old Mar 7, 2013 | 02:13 PM
pinkytoe69's Avatar
Couple examples. Look for 5x6.5" bolt pattern.
Pro Comp 87 Gloss Black Wheel (15x8"/5x6.5") : Amazon.com : Automotive
Lucky8 Llc. - Take the road less traveled...
Old Mar 7, 2013 | 02:58 PM
Sam95disco's Avatar
What size? 17+
Old Mar 7, 2013 | 03:00 PM
greenharoguy's Avatar
Aftermarket rims are always possible. Just start making calls to makers of rims you like, tell them the bolt patter size, and they can make just about any rim fit. Its not going to be the cheapest route, but I have done it twice on my Fiats because of the rarety of the bolt pattern.
Old Mar 7, 2013 | 03:19 PM
fishEH's Avatar
You probably won't be able to walk into Pep Boys and grab some wheels. But there are some out there. SafariHP had some but they're mostly out of stock now. Raceline wheels has some, too.
Old Mar 7, 2013 | 04:11 PM
keoni004's Avatar
Pro Comp 87 Gloss Black Wheel (16x8"/5x6.5") : Amazon.com : Automotive Pro Comp 87 Gloss Black Wheel (16x8"/5x6.5") : Amazon.com : Automotive
Wow, I didn't even think to consider Amazon. Free 2-day shipping? Thank you.
Old Mar 7, 2013 | 04:19 PM
CUpgt's Avatar
4Wheel Parts has the Pro Comp 87s as well for pretty cheap. I found a discount code and got 5 16x8 with 4.25" backspacing (website says 4.5" but they are really 4.25") to the door for around 400 bucks
Old Mar 7, 2013 | 07:50 PM
yelah's Avatar
Can you get those in white? or alum.?
Old Mar 8, 2013 | 12:45 AM
Jake1996D1's Avatar
Terrafirma makes a bunch of wheels as well. They have white aluminum rims. None of them are cheap though
Old Mar 8, 2013 | 08:18 AM
antichrist's Avatar
Not all that exclusive. Any 16" Series, D90, D110, Defender or RRC wheel, back to 1948, will fit.
Only one exception I'm aware of that won't are the two part rims, not enough off-set to clear the calipers without spacers.
Be careful what you use. The OE alloys are the strongest OE wheel, second only to the Wolf's.
