95 Fuel pump
Old Mar 24, 2015 | 06:30 PM
TheButcher's Avatar
4th Gear
Default 95 Fuel pump
So, I've made it though almost everything thanks to the help of the other fuel pump thread. Unfortunately I'm now stuck thanks to the "union" nuts? Im not getting it. I order my pump from JC Whitney and thought it was coming ready to go. RoversNorth says you need new nuts. Which looks to be true. But I don't understand how it works. Anyone familiar with these pumps?
Old Mar 24, 2015 | 06:59 PM
OverRover's Avatar
Put the nuts on 1st, then the olives. Install lines.
Looks like this > LAND ROVER FUEL PUMP RANGE CLASSIC 95 DISCOVERY 1 94-96 ESR3926 USED | Miami British Corp.
This might also help > http://www.4x4wire.com/rover/mainten...elpumpinstall/
Old Mar 24, 2015 | 07:40 PM
TheButcher's Avatar
4th Gear
Ok and I guess they should have either been with the pump or ordered separately. Goodie. Thanks OR
Old Mar 24, 2015 | 08:00 PM
OverRover's Avatar
That is a PITA that those parts are missing. You'll need (2) Union Nuts NRC9770 and (2) Olives NRC9771. Good thing is most, if not all LR parts places have these in stock.
Good Luck!
Old Mar 24, 2015 | 10:20 PM
TheButcher's Avatar
4th Gear
Yea rover north has them. Thanks again. Just grumpy I have to wait for shipping and another day off. Also, I should do that gasket as well?
Old Mar 24, 2015 | 11:41 PM
fishEH's Avatar
Yes, do the gasket with it for sure. If you think you might have problems with the retaining ring order a new one of those as well.
Travelor
Sep 24, 2015 06:11 PM
JumPeR04
Apr 7, 2011 09:52 PM
leadfoot
Sep 13, 2009 09:51 AM
discoken
Nov 4, 2008 12:39 AM
