are the 96' and 97' harnesses interchangeable?
Old Jan 27, 2025 | 08:02 PM
amoody's Avatar
5th Gear
Default are the 96' and 97' harnesses interchangeable?
hey everyone, i just swapped in a new (used) 4.0 v8 motor from a 97 into my 96 disco, was wondering if I could also use the harness from that year or if there's some incompatibility.
i know i know, i can just take both of them out and compare side by side but just checking if anyone knows off the top of their head.
would save me a lot of work
thanks!
Old Jan 27, 2025 | 09:53 PM
JohnZo's Avatar
Those years used the same engine management system (GEMS), so I guess the wiring is the same. But this is not knowledge from experience.
Old Jan 27, 2025 | 09:59 PM
disco96sd's Avatar
I know there are different harnesses for Left and Right hand drive and of course GEMs gas vs diesel
I did find that this part number below for left hand drive GEMs is for a VIN forward so you need to check your VIN to be sure - there is a difference in the smog control system between 96 and 97 MY's so possible a difference in the wiring harness
AMR4209
From VIN TA163104
Old Jan 28, 2025 | 08:15 AM
Best4x4's Avatar
96 should all be non AEL vs 97 which could be both. That would be the only difference in the USA.
Danny Lee 97 Disco
Apr 8, 2013 06:11 AM
kman3786
May 25, 2010 11:46 AM
mumjo
Feb 20, 2010 08:10 AM
Trag
Mar 6, 2009 10:35 AM
Feach
Apr 28, 2006 10:35 AM
