96 disco running hot
Old 11-22-2022, 01:09 PM
JohnZo's Avatar
Default Fast and Furious
Originally Posted by Dmfw2x
OK I bought a fan clutch autozone but it was miss packaged. So I cleaned the temperature sensor it was packed with grime, drove it last night for about an hour and it got to 200. This morning I made damn sure I all the air was out of the system. Drove around for an hour and saw 195 to 200. Thanks for the help
If the thermostatic coil was packed with crud, it probably was from the silicon fluid leaking out of the clutch. If the fluid leaks out, they don't work good. Symptoms will be high temperature when stopped or driving slow in line at the drive-through.
Driving at speed tends to cool the radiator without needing fan support. So, keep driving fast and furious and everything should be all right.
Jimdvr
07-17-2022 02:42 PM
kman3786
05-25-2010 11:46 AM
timothyfuqua
10-12-2009 04:34 PM
DiscoSam2
10-29-2008 11:26 AM
madison263
06-21-2007 07:20 AM
Quick Reply: 96 disco running hot
