96 discovery
Old Mar 30, 2012 | 03:06 PM
fire771087's Avatar
4wd High
Default 96 discovery
having trouble getting my window regulator out any ideas
Old Mar 31, 2012 | 01:37 PM
skorten's Avatar
I haven't looked into this yet, but I need to replace my driver side. From working on other cars, I'm guessing you'll have to drill out the pop rivits for removal, and then get yourself a rivit tool to install the new.
Old Mar 31, 2012 | 03:07 PM
I did not have to drill out anything. Have removed at least three of them and replaced rollers with teflon squares (slides) that snap over the remaining studs (so those don't have to drill out either). See https://landroverforums.com/forum/di...tor-fix-41124/
Old Mar 31, 2012 | 05:39 PM
slanginsanjuan's Avatar
i totally drilled. super easy. depends on what method you go with. check the sticky.
