97 Discovery Accelerates w/bad shake under load
Old Jan 5, 2019 | 05:14 PM
xathor's Avatar
It was over spec... I had them cross reference the Airtex E3270, they had a similar pump for $70 vs the less than $40 on Amazon for the Airtex. I was already working on the truck that day so I went ahead and purchased the one from O'reilly.
For what it's worth, a 200hp naturally aspirated motor needs around 16 gallons per hour of fuel flow. The Rover V8 operates at a pretty low pressure, if I recall its like 37psi, which makes the requirements very low.
The O'reilly part number is E16008 and will support around 300hp.
You'll also want a new strainer: S13003
Old Jan 6, 2019 | 08:46 AM
ihscouts's Avatar
It's a return fuel loop, anything that doesn't get pumped through the injectors will just end up taking a long trip back to the tank.... albeit at a quicker rate than the line is used too...... They should've used a 300hp engine to weigh anchor in the Rover Love Boat.
elrocha69
Sep 8, 2018 07:05 AM
Jason Andrew
Nov 27, 2014 09:25 AM
misterme
Jul 2, 2014 09:06 PM
misterme
Mar 9, 2014 07:59 PM
Speegles
Jun 19, 2011 11:58 AM
