'97 Discovery Exhaust Manifold Replacement
I have a cracked right exhaust manifold on my '97 Discovery. There is a 2001 Discovery in a local junkyard with good manifolds. Will these fit the '97? Any comments on what size manifold bolt heads are used on the Disco? Torx or ???
Thanks!
Vince
Thanks!
Vince
They will not fit a D1 better off giving Paul a call.
paulgrant@mac.com
classicroverparts@gmail.com
http://stores.ebay.com/Classic-Rovers
203-770-1699
paulgrant@mac.com
203-770-1699
Had a successful weekend with the Discovery.....both manifolds were still there, and the bolts are indeed 12 point 12mm. All of them came out easily using a regular 1/2 inch ratchet and socket. The lower exhaust bolts were broken off by someone previously to remove the downpipes.
That the bolts all came out so easily and the metal gaskets looked good made me wonder if the heads had been taken off recently for some reason? Rebuild or head gaskets? Spark plug wires and plugs looked fresh, too. Truck is rusty body-wise and that is probably why it is in the scrapyard.
You guys know your Land Rovers better than I do... Should I go back and pull the valve covers and see what it looks like in there?
My next project on my '97 is to pull the heads and fix a blown head gasket that is causing overheating. So a possibly rebuilt set of heads could be useful....
Thanks again for the great comments!
Vince
Vince
Luckyjayb
12-20-2016 02:48 AM
PistonBroke
09-19-2016 09:19 AM
