97 key switch wiring question
I bought a 97 se7 that the key switch was out on and was starting with a screwdriver. I want to put in a aftermarket key switch, but I have a question about the wiring. I found the wire that I believe is the acc(first notch), however I have 2 wires that energize in the run position(second notch). My question is can I put both wires under the same lug on the new switch?
well , I'll chime in....the original switch has 2 "on" positions before the start position.
in the first on position....usually the only thing noticeable is that the radio works.....in the second on position the fuel pump, is energized as well as the window(and most other electrical circuits).....I dont see why you couldnt combine them.....let us know how it goes
