97 key switch wiring question
Old Apr 22, 2016 | 10:34 AM
lestro's Avatar
Default 97 key switch wiring question
I bought a 97 se7 that the key switch was out on and was starting with a screwdriver. I want to put in a aftermarket key switch, but I have a question about the wiring. I found the wire that I believe is the acc(first notch), however I have 2 wires that energize in the run position(second notch). My question is can I put both wires under the same lug on the new switch?
Old Apr 23, 2016 | 12:22 PM
lestro's Avatar
anyone know?
Old Apr 23, 2016 | 09:59 PM
XCELLER8's Avatar
well , I'll chime in....the original switch has 2 "on" positions before the start position.
in the first on position....usually the only thing noticeable is that the radio works.....in the second on position the fuel pump, is energized as well as the window(and most other electrical circuits).....I dont see why you couldnt combine them.....let us know how it goes
Old Apr 24, 2016 | 10:04 AM
lestro's Avatar
Thanks for the input, I'll give it a try,
primussucks
Mar 25, 2015 02:04 PM
fishEH
Jan 31, 2014 11:21 AM
Madlands
Dec 10, 2013 12:50 PM
zigzag3141
May 13, 2013 09:12 PM
s10lowrider1994
Dec 29, 2012 07:53 PM
