98 disco rough idle
98 d1 p1317 code with rough idleSome sources say to check the crank sensor, others say its an abs code. This popped up today after I fixed a bad ground. Edit: I also have a p0451 and have read it may be connected? Both of these popped up today after I fixed a bad ground that was causing a no crank no start issue
right, but what about the p1317? Im finding conflicting information. And on the d1, isn't that ael sensor part of the fuel pump?
the 30a link from under the hood has been gone the entire time ive had the car
could the 2 codes be connected somehow?
I would start by checking the throttle plates and making sure the throttle body bore (and plates) are clean. And if there are deposits, clean them off. Make sure the PCV is working. Ensure there are no vacuum leaks. Yeah, I know thee might not be codes, but common things which can happen to old vehicles which can throw owners off. Just takes a couple minutes to rule out.
Shawn951discorover
Feb 9, 2017 11:11 PM
