About Stock/Spare Steelies
#41
As Tom stated eariler (original point of post) The "spare" steel wheels supplied with the early discos are absolutely NOT designed for HD, Off-road use. They are WAY too light for long duration off road use and could deform slightly during a heavy impact. Designed as an emergency spare for short term use only.
Cheap = Cheap
Cheap = Cheap
#42
Cheap = Cheap
Cheap = Cheap
http://www.youtube.com/watch?v=QtexoMZJ7Y0
#43
I beg to differ, the only place they use that spare rim as a "spare" is in North America, everywhere else in the world they were the cheaper rim option and they seem pretty strong to me.
![Cool](https://landroverforums.com/forum/images/smilies/kKt1IJ6.png)
You are correct; Those wheels are supplied as the "shipping" or "transport" wheel and as the base option in some markets. Not necessarily meant as or even offered as the Heavy Duty or Desirable Off-Road wheel choice. That's all I'm sayin'... sure you can use em but they're not very strong.
#44
I will agree that they are not as strong as the Series/NATO/alloy rims but they are pretty strong.
The only reason the tire blew was he landed on it not only hard but off camber so the rim tore into the tire and I dont care what rim you are running and landing a 4500lb SUV from 4ft in the air its going to deform the rim.
And you have to agree that he was abusing the hell out of those rims with street tires not any kind of offroad tire so the rim hit the ground with the full force and weight of the truck on it.
Had he had a stronger tire I think the rim would have been just fine.
#45
Cheap = Cheap
Cheap = Cheap
http://www.youtube.com/watch?v=04Tb-Wrn5fI
![](http://www.thegreenoval.com/chinese/sale/mpi/mpi01.jpg)
#47
Spence - that is an inaccurate look-a-like of a CT rig... not the right wheels or tyres along with many other external errors. Mud Flaps??? Seriously, c'mon...
Uncle Spike - I think we have been and still are saying the same damn thing. The spare LR Disco wheel is not as stong as the NATO/WOLF/Series rims and should not be used for HD off-road use as they will not hold up over time.
IF the spare wheels LR supplied with their Disco's had been up to CT specs then I'm sure they would have been used for that purpose. Since they were not strong enough for the CT contenders from 90 - 96 then I'm guessing LR did not consider them adequate for HD off-road abuse.
Much Love.. .peace out my brotha...
I'll send you FLA oranges if you send me fresh Michigan Blueberries as a much better tasting alternative to an olive branch.
#48
#49
Cheap = Cheap
Cheap = Cheap
In any case, the Discovery steel, NTC5193, is rated at 1650kg
The Wolf, ANR5593, is rated at 2200kg.
The load capacity I can find on the Tornado rims is 850kg (though that seems too low to me, though it is within the Discovery's Gross axle load rating)
#50
I know I shouldnt run mine flipped inside out but Ive never bent one and if I do there plenty cheap enough so I really dont care. I did run a full bead of weld around the center piece on both sides to help stiffen them up instead of the factory only had a spot weld every few inches. Would I recomend any one flipping them NO but it can be done. The only reason I do that is Pennsylvania wont allow wheel spacers and I cant find the rite offset wheels yet.
BimmerFreak
09-18-2010 05:20 PM
