About Stock/Spare Steelies
Old Nov 19, 2010 | 01:09 PM
  #41
Cosmic88's Avatar
Default Not up to par....
As Tom stated eariler (original point of post) The "spare" steel wheels supplied with the early discos are absolutely NOT designed for HD, Off-road use. They are WAY too light for long duration off road use and could deform slightly during a heavy impact. Designed as an emergency spare for short term use only.
Cheap = Cheap
Old Nov 19, 2010 | 07:05 PM
  #42
Cheap = Cheap
I beg to differ, the only place they use that spare rim as a "spare" is in North America, everywhere else in the world they were the cheaper rim option and they seem pretty strong to me.
http://www.youtube.com/watch?v=QtexoMZJ7Y0
Old Nov 19, 2010 | 10:14 PM
  #43
Cosmic88's Avatar
Default Thanks for proving my point...
Forward to 3:25 into the video... I appreciate your help in proving my point. I also believe you could consider that "slightly deformed".
You are correct; Those wheels are supplied as the "shipping" or "transport" wheel and as the base option in some markets. Not necessarily meant as or even offered as the Heavy Duty or Desirable Off-Road wheel choice. That's all I'm sayin'... sure you can use em but they're not very strong.
Old Nov 20, 2010 | 04:18 PM
  #44
I will agree that they are not as strong as the Series/NATO/alloy rims but they are pretty strong.
The only reason the tire blew was he landed on it not only hard but off camber so the rim tore into the tire and I dont care what rim you are running and landing a 4500lb SUV from 4ft in the air its going to deform the rim.
And you have to agree that he was abusing the hell out of those rims with street tires not any kind of offroad tire so the rim hit the ground with the full force and weight of the truck on it.
Had he had a stronger tire I think the rim would have been just fine.
Old Nov 21, 2010 | 12:00 AM
  #45
Spencerfitch's Avatar
Cheap = Cheap
well it appears they used these for the camel trophy
http://www.youtube.com/watch?v=04Tb-Wrn5fI
Old Nov 21, 2010 | 09:13 AM
  #46
They used these rims for the Camel Trophy, that truck is a look-a-like.
Mantec supplied the winch bumper not ARB like in that pic.
Old Nov 22, 2010 | 08:55 AM
  #47
Cosmic88's Avatar
Default Rumble?
Spence - that is an inaccurate look-a-like of a CT rig... not the right wheels or tyres along with many other external errors. Mud Flaps??? Seriously, c'mon...
Uncle Spike - I think we have been and still are saying the same damn thing. The spare LR Disco wheel is not as stong as the NATO/WOLF/Series rims and should not be used for HD off-road use as they will not hold up over time.
IF the spare wheels LR supplied with their Disco's had been up to CT specs then I'm sure they would have been used for that purpose. Since they were not strong enough for the CT contenders from 90 - 96 then I'm guessing LR did not consider them adequate for HD off-road abuse.
Much Love.. .peace out my brotha...
I'll send you FLA oranges if you send me fresh Michigan Blueberries as a much better tasting alternative to an olive branch.
Old Nov 22, 2010 | 12:28 PM
  #48
Sounds good to me.
Old Nov 23, 2010 | 08:53 AM
  #49
antichrist's Avatar
Cheap = Cheap
Ummm...no, not what I said. You may have inferred it, but I in no way implied.
Originally Posted by antichrist
The spares don't look anything like NATO wheels, nor are they as strong.
I could just as easily have said The alloys don't look anything like NATO wheels, nor are they as strong and been just as accurate.
In any case, the Discovery steel, NTC5193, is rated at 1650kg
The Wolf, ANR5593, is rated at 2200kg.
The load capacity I can find on the Tornado rims is 850kg (though that seems too low to me, though it is within the Discovery's Gross axle load rating)
Old Nov 23, 2010 | 09:30 AM
  #50
Long Haul's Avatar
I know I shouldnt run mine flipped inside out but Ive never bent one and if I do there plenty cheap enough so I really dont care. I did run a full bead of weld around the center piece on both sides to help stiffen them up instead of the factory only had a spot weld every few inches. Would I recomend any one flipping them NO but it can be done. The only reason I do that is Pennsylvania wont allow wheel spacers and I cant find the rite offset wheels yet.
timdunbar
Oct 9, 2010 05:57 PM
BimmerFreak
Sep 18, 2010 05:20 PM
sloppyjoe
Aug 24, 2010 08:44 PM
leadoverdistance
Sep 22, 2007 11:15 PM
SnowmanJon
Jun 23, 2007 11:37 PM
