ABS disabling question and issue
I thought it was the 40A ABS pump fuse?
There very clearly is a 40Amp Fuse (or a fusible link never seen this kind of fuse before) labeled ABS pump under the hood and a separate 30A bladed fuse called ABS Valve.
I pulled the 30A ABS valve because when you pull the 40A ABS Pump one the Disco won't idle.
I also today pulled the 5A ABS fuse in Satellite one under the dash.
So, is the thing safe now or should I unplug the pump too?
So, just pull the valve fuse then? Just what does the 5A fuse in Satellite 1 do anyway?
