Abs light
Old Nov 19, 2010 | 05:34 PM
Garrett's Avatar
I think I'm failing.
I jump terminals 5 and 15, the connector has 1, 8 and 16 already stamped on the plastic so it's not hard to find.
I jump them then I put the key to Position II and nothing happens
My Rover is a 96. Any ideas? Yes my Anti-Lock light is on.
Old Nov 20, 2010 | 03:02 AM
jbriggs's Avatar
I did the same thing the first time too. My plug was upside down. Try counting them the other way. Mine wasn't marked with numbers for each slot.
Old Dec 2, 2010 | 09:06 PM
calebbo's Avatar
I don't know what the ABS Warning Light Relay is.. can somebody take pictures please?
I have a 1995 Land Rover Discovery I
Thanks,
- C.Bo
Old Dec 7, 2010 | 12:01 AM
SurfRat's Avatar
Default BIG Thanks!
This one thread on ABS blik codes via paper clip probably saved me BIG $$$$. No service station around here will pass a vehicle with and ABS light on. Turned out to be a 2-13... rear left sensor air gap... taped it back in a little... cleared the code... 200 miles later all is good! BIG THANKS to the author and everyone on this forum!
Old Jun 28, 2011 | 12:34 AM
wheelgarage's Avatar
Found the link to the PDF file on the net......
http://www.horodecki.pl/rajdy4x4/ABS...ng%20light.pdf
Old Mar 6, 2012 | 10:48 PM
lostl13's Avatar
i need this for my 2004 Disco II...
Old Dec 29, 2012 | 02:49 PM
reboot's Avatar
1) When the codes say example Left side, that means as if you're sitting in the vehicle facing forward, it's your left? (which would be the drivers side on an American vehilce?)
2) To pull the sensor out on the front wheels, can you wiggle them out or do you have to remove the two large bolts next to the sensors?
I keep getting a 2-14 blink code, I tap the drivers side sensor (left side as sitting in vehicle) but the code keeps coming back with the ABS light. I get the slippage once in a while. Maybe it's time to pull the fuse? Any feedback appreciated.
Old Dec 29, 2012 | 03:05 PM
ihscouts's Avatar
Are you tapping it in until it bottoms? If it keeps sliding out then you'll need a new rubber bushing and metal retainer for the ABS sensor. Go here - RovahFarm for all your new Land Rover Parts and Accessories
Old Dec 29, 2012 | 04:07 PM
reboot's Avatar
Yes, I have tapped it in twice. I'm assuming it hit bottom. I'm doing the front left as if sitting in the vehicle per code 2-14.
Is this what you are referring to?
Thanks for info
Old Dec 29, 2012 | 05:19 PM
ihscouts's Avatar
Yep. When it bottoms against the CV it makes a solid "tonk" sound.
