ac switch
Ok so I tested the plug on the compressor and I don't have 12 volts. I jumped the compressor and It kicked in and I had cold air. I changed the k108 relay and I checked all the fuses. I also put a NEW ac switch in and still nothing. I pulled the new switch and put 12 volts to it and when I pressed the switch the light came on. SO WHY DO I NOT HAVE POWER TO THE SWITCH NOR THE PLUG?
I pulled the ac switch and put an old white plug i got out of the junk yard in the back and tested the switch by putting a 12 volt supply to the plug and pushing in and out and the light came on. By playing with the plug I realized (I think anyway) that wire number one and number three on the plug should be hot. When I energized either of them the orange light on the plug lit up. On the white plug in the car only number 3 is has power. Is my thinking right? I've looked at the rave and I can't find what I'm looking for. Where's my problem? Any help would be greatly appreciated.
abran
Aug 5, 2014 06:13 PM
AZRover
Jul 2, 2012 06:43 PM
