Adaptive value reset
Im running a 97 D90 NAS, going to try it with an android phone. Resetting the adaptive values, did that go well?... little leery introducing new code into the ECU.
Thanks!
Were you concerned at all into during new code into the ECU??
I know I need to reset the TPS, and this reads like the best/ most cost effective way of doings it... but I’ve never done something like this.
Thanks!
I know this is an old post...
Having the same high idle issues, reseting the TPS has worked in the past. So to have an option to do it myself for 60 bucks is awesome!
But... is there anything "bad" that could happen introducing this software fix to the ECU??
The info on this forum is amazing!
Thanks
Thanks
I think that was a one off just with the android device/obd device glitching.
No new code is being introduced to the ECU.
resetting the adaptive values just changes the air/fuel mixture numbers back to stock settings.
it works really well and will address a high idle issue.
I have the older Britpart Lynx System for a D1 and I tried the 10AS sync and it totally locked my 10AS up. I slapped another one in and I was good to go, but I sure wish I could get the Britpart Lynx to program the ECU/10AS as I'd like to pair a few ECU's and 10AS units I have as spares.
