air conditioning cuts out
today i noticed while driving my 99 disco I, the air conditioning abruptly shut down. i turned fan off and on again and it restarted. this happened twice today. maybe unrelated but my check engine light was on for 2 days then went out. it was not on when the a/c did it's new trick! temp guage is is normal....
My 97 the fan would cut out at random times on heat or AC. It never happened enough to bother troubleshooting but I was thinking either a loose connection or a failing blower motor.
Try to pay attention to whether you hit a bump or anything out of the ordinary when it happens. That should give a clue to what's causing the problem. If it cuts out after you hit a bump I'd think loose connection somewhere in the system.
