Air conditioning help Disco I
Old Jun 19, 2012 | 05:50 PM
trospierski's Avatar
Default Air conditioning help Disco I
Hey guys, need a little help here. My air conditioning isn't working in my disco. I have no power to the compressor clutch. If I jump from battery to the compressor coil it works and blows Ice cold, but I can't find an accurate wiring diagram or the location of the relay that controls the compressor. Can anyone out there give a guy a hand??
Old Jun 19, 2012 | 06:24 PM
4100xpb's Avatar
Have you downloaded the RAVE (see D1 Tech Section if not)? It has the electrical schematic for the AC compressor system, along with locations and photographs of most components.
Old Jun 19, 2012 | 06:36 PM
slanginsanjuan's Avatar
my switch went bad. we took it apart and made sure the connections were good. it works again but ill need a new one soon enough.
Old Jun 19, 2012 | 06:40 PM
nice little blog mark. good going.
I'm trying to download the manual now.. Are you talking about the AC Switch on the climate controls??
Old Jun 19, 2012 | 06:42 PM
the control switch on th dash you use to turn it on and increase and lower ac power. the metal connections inside had rusted and the AC did not work at all. we sanded the connections down and re-established contact. it's shaky but the ac itself works great.
Old Jun 19, 2012 | 06:43 PM
it is a d1 right? put the year and model in your sig so everyone knows.
Old Jun 19, 2012 | 06:46 PM
I can't download the manual because I don't have a disc burner on my computer.. Any other ideas on the wiring diagram or location of the relay? If I knew where the relay was located I could check to make sure voltage is comng in and going out of the relay. As for the switch I tried to pull it out and I can't get the climate control out to check the switch.
Old Jun 19, 2012 | 06:48 PM
Yeah it's a 1997 disco I..
Old Jun 19, 2012 | 06:52 PM
you don't need to download it. you can use it online. Savannah Buzz has all the links in his signature. find him and you will find your answers.
