Altenator recommendations? 98 50th anniversary edition 4.0l v8
Old Oct 3, 2023 | 12:54 PM
Trashpanda's Avatar
Default Altenator recommendations? 98 50th anniversary edition 4.0l v8
I know there's posts about this, but I'm new and having a hard time finding them. Altenator was draining the battery, put a reman in, its not charging. Are there any brand or replacement recommendations?
Old Oct 3, 2023 | 01:11 PM
outono's Avatar
The best i've found is: Denso AMR4247G
Old Oct 3, 2023 | 01:19 PM
Trashpanda's Avatar
Thanks
Old Oct 3, 2023 | 03:34 PM
Best4x4's Avatar
Use a 95-98 P38 RR Alternator and gain 20amp's. 120 vs 100
Old Oct 3, 2023 | 05:47 PM
WaltNYC's Avatar
Do you need to change the pulley?
Old Oct 3, 2023 | 05:50 PM
Trashpanda's Avatar
no, everything is brand new and tight
Old Oct 3, 2023 | 06:08 PM
Best4x4's Avatar
Nope pulley on a P38 Alternator is identical to a GEMS 4.0L setup.
"If" you have a 94/95 D1 with the 3.9L V8 you can also drop the same P38 alternator in. It just requires a single mod & there are two ways to do it. I personally prefer the smaller pulley so it is further away from the $$$ and getting harder to find upper fan shroud piece, however you can swap the pulley over to the P38 Alternator, or do what I find best, and that's swapping the 94/95 Tach to a 96-99 GEMS Tach. Then you are good to go. My 95 has a P38 Alternator & the 96-99 GEMS Tach & it works like a charm.
Old Oct 3, 2023 | 08:55 PM
94Disco1's Avatar
@Best4x4 - have you covered this GEMS Tach mod anywhere? Would love to know more. I've got a 1994 and I am constantly fighting to keep a good tach connection on the back of the alternator... If you haven't covered in another post...care to share more about install?
Old Oct 4, 2023 | 07:04 AM
disco96sd's Avatar
I went the OEM LR rebuild route - no problems - had one year warranty and it only cost $100 with exchange - they paid the postage
Old Oct 4, 2023 | 10:32 AM
jvarnadoe's Avatar
RockAuto has a new 120amp alternator for the Disco - $171 with no core charge. It's made by Wai Global. Anyone have experience with that brand?
https://www.rockauto.com/en/moreinfo...=1309&jsn=1309
