Alternator Puzzle
Alternator Puzzle
I replaced the Alternator 4 months ago. Tach stopped working yesterday, so I ordered the replacement (lifetime warranty) and when it came in I took the dead one up to Oreiley and it came up Bad.
Replaced started the truck and the Tachometer sprung to life. Problem solved so I thought. I got in the truck a bit later, started it up, rolled the windows down, opened the sunroofs, and turned the A/C on. I had not moved the vehicle 30 feet before I realized that the Tach was once again dead.
What could kill the Alt so quickly, could a short in either the sunroofs/window motors or the blower motor kill the Alternator that quickly? Perhaps a problem with the Battery??
Do yourself a HUGE favor and buy a used alt off of e-bay, then when you have enough money buy a second used one.
I went through 4 lifetime warranty alternators in 2 years, 2 from AutoZone and 2 from Advance Auto.
The first one lasted a year, the next 3 lasted no longer than 3 months each.
They are crap rebuilt alternators.
You either need to buy a brand new one or a used one.
There is lots that could have shorted it out.
I installed a "new" alt and it was bad right out of the box.
This is common for these places, they all use the same rebuilder but they put it in a different box.
It is not very likely to be a problem with your truck, it could be, but not likely.
I plan on putting the next one in the truck with the blower off, compressor switch off, windows already open and then start it up then power up each one of these one at a time and see if one of them shorts it out. If everything works, then I will buy a new one when this one fails 3-4 months down the line. Waiting till Wed for the part, will post back.
