Alternator woes - pissing me off.
Old Nov 23, 2011 | 02:28 PM
  #61
calebbo's Avatar
I can get my hands on a mm for like $35
Old Nov 23, 2011 | 05:06 PM
  #62
Danny Lee 97 Disco's Avatar
We should build up a supply of them to do a pool for forum members.
I will take a look at the RAVE Electrical section, I printed mine out and put it in it's own three ring binder with a Pic of MEANDEROVER under the front cover and tabbed it into the different systems for easier reference. I will take a look and let you know soon.
SAVANNAHBUZZ may beat me to it. I have a question, is that excitation voltage intended to be constant. That may be why my tach acts flaky at startup and on various occasions.
That is the main driver toward me needing a ScanGuage, to better monitor rpm's and temps as well as other live data.
Old Nov 23, 2011 | 05:33 PM
  #63
Fitzy250's Avatar
all this alternator talk is crazy so check this out my dissco as a alt from a 97 4 door satern sedan swaped pully and you need to take the bolts out to split its case but barlely split it just enough to clock it so the mounts line up and your out like 70 bucks. this info came from the PO of my disco got ahold of him by finding discount tire paperwork in the glove box very helpful im not sure how or where he found this but it works and its not a small fortune.
Old Nov 23, 2011 | 06:25 PM
  #64
And does not compare to the Italian made MM either.
As long as you're happy with it, and if it is rated heavy enough output which you will find out one day or another.
Old Nov 23, 2011 | 08:15 PM
  #65
Do the wires mate up with no issues?
Can you take a pic and get a model number off of the alt?
Do you know the amps of it?
Old Nov 23, 2011 | 08:53 PM
  #66
Fitzy250's Avatar
ill get a pic and see what i can find the PO was running 5 offroad lights and claimed no problem im running 3 right now and havent had a problem yet knock on wood and this alt has been on for almost 2 years so im told like i said all this is comming from the previous owner
Old Nov 24, 2011 | 11:12 AM
  #67
As long as it can handle the load, that's great.
The MM's are supposedly designed for the heavy duty requirements and are made more waterproof for things like fording and such.
Old Nov 24, 2011 | 04:33 PM
  #68
Fitzy250's Avatar
Took some pics and my kids say my dog ate the sd card adapter so untill i track one down i cant get the pics up. I took a better look and the way its bolted up is a little hokey but everything is tight i didnt see any wires spliced together ill post the pics as soon as i can
Old Nov 24, 2011 | 04:43 PM
  #69
Fitzy250's Avatar
notice how its mounted
Old Nov 24, 2011 | 05:06 PM
  #70
We do not like little hokies, never know when they will break down but usually at a very bad place and time. The main thing is how well the output is regulated and that it handles the load. If it swings too wildly in the output you could be in for a nasty surprise. Not saying you will, but the invitations have already been sent out for a visit from the gemlims.
Have fun when it does let go. Usually those kind of cheap fixes lead to costly fixes later on down the trail.
humroot
Feb 28, 2013 10:58 AM
edh
Aug 21, 2012 07:30 PM
DiscoArt
Dec 26, 2009 11:44 PM
JumPeR04
Dec 17, 2009 07:57 PM
mgabriel
Dec 11, 2008 11:53 PM
