Antenna location
Antenna location
So I looked through the rave wanting to know where the darn antenna is. My reception is kinda crappy and thought it was a bad antenna connection. In the rave it states something about it being located in the rear right window. Can anyone be more specific. And does it have an antenna amp as well. I just want to listen to the radio with out losing signal. Thanx in advance.....
no problem kamileon, im glad to be able to answer a question instead of ask one for a change. but i dont get why you guys are having bad reception. im 130 miles or so south of chicago and get 720 and 780 AM in clear as a bell, i know AM travels well, but im still impressed, and on a good day i get Q101 (101.1 FM) in better than some local stations.
I can't remember where I read this, or if it was all a bad dream, but I think I remember reading something about it being a diversity antenna system. One antenna is dual purpose AM/FM, while the other is only FM. Both FM signals are combined and routed to the receiver as one. The reason is so that you can have an unobstructed FM signal path from the transmitter, regardless of the orientation of the vehicle.
But like I said I have no idea where I read that, so I might be thinking of something else. My head is filled with all kinds of radio and navigation BS from work, and sometimes I can't remember what goes with what.
North is down, correct?
Roveroh
08-07-2008 09:42 AM
mikemeyer0
05-26-2005 01:44 AM
