Any chance this rotor can be saved? (pics)
Old Sep 14, 2010 | 08:14 PM
geek_IM's Avatar
Default Any chance this rotor can be saved? (pics)
So I'm preparing for this weekend when I am going to (try) to install all new rotors, calipers, pads and all the seals in the front from the axle seal all the way out to the drive member gaskets. That's $300 in seals alone. OOoof.
Anyhoo, I am rounding up all my parts n stuff and discovered this:
It seems that the bag the rotors were in somehow let in some moisture and left the corroded patches you see here. It is not bad, well, in the sense that you can't really feel any difference in the surface. The tooling lines run pretty much continuously clean through the patches, it's not deep.
I'm just sick about this - they are brand new and it never occurred to me to check the BOTTOMS - I just opened the box, saw what looked like clean rotors and put them on the shelf.
Should I try to sand it off? Scotchbrite? Just put them on and hope for the best?
Old Sep 14, 2010 | 08:32 PM
Danny Lee 97 Disco's Avatar
I would not be very concerned about it, it's just surface and the first few times you apply the brakes, it will be gone maybe even the first time.
Old Sep 14, 2010 | 08:48 PM
Put them on and drive the thing, dont worry about it.
Old Sep 14, 2010 | 09:00 PM
lordmorpheus's Avatar
x3 on putting them on and not worrying. I would bet money the corrosion is going to be gone after the first stop from 40MPH.
Old Sep 14, 2010 | 09:17 PM
If you got the right kind of pads, they have a built-in cleaning system (commonly known as friction).
Old Sep 16, 2010 | 06:26 AM
Long Haul's Avatar
You can clean them up with some scotch brite if you feel you need to but I would just put them on the first time you brake itll be gone.
Old Sep 16, 2010 | 08:45 AM
okdiscoguy's Avatar
Just put them on. It will probably wash off when you clean the oil off them when installing..
Old Sep 16, 2010 | 09:58 AM
Don't worry about it, it will be gone after 30 minutes of driving.
Who's pads will you be installing? Make sure to use lots of sound deadening material and do a full 2 quart brake flush when done.
s10lowrider1994
Sep 27, 2023 09:40 AM
Fallstaff
Feb 2, 2015 09:30 AM
thehun
Mar 7, 2013 01:35 AM
elboy0712
Feb 19, 2010 07:09 PM
DuplinDisco
Feb 4, 2008 08:33 PM
