ATF vs. 80wt - 90 in R380
Old Aug 2, 2010 | 05:49 PM
Cosmic88's Avatar
Default ATF vs. 80wt - 90 in R380
Yet another opinion / experience based thread. Recently I heard from a friend that in the R380 Tranny he knew someone who used 80w -90 gear oil instead of the factory recommended ATF!
Now in my mind I'd stick with what LR recommends but ya never know...
I know the 5 spd. R380 tranny is pretty rare in the Disco but there are a few of us out there. Let the opinions fly...
Old Aug 2, 2010 | 06:08 PM
Long Haul's Avatar
I think you want to use 80w90 but you might want to wait for Antichrist to chime in.....hes pretty knowledgable on the R380s
Old Aug 2, 2010 | 06:25 PM
AntiChrist uses RedLine MT fluid if I remember correctly.
I think there was a TSB on this and it said to use straight 80w, but I could be wrong, its almost happened before. lol
Old Aug 2, 2010 | 08:26 PM
antichrist's Avatar
Yeah, regular gear lube it not to be used in the R380.
There was in fact a TSB from Rover that MTF should be used.
http://www.redlineoil.com/product.aspx?pid=45&pcid=7
Old Aug 2, 2010 | 08:30 PM
See, I told you there was a TSB. lol
Thank you for clearing that up AntiChrist.
Old Aug 2, 2010 | 08:58 PM
Cosmic88's Avatar
thanks a lot for the input. I'll have to try the MTL 70W80 GL-4 when I do the tranny next.
What do you think when switching? Would you drain and flush completely or gradually flush over time?
Old Aug 3, 2010 | 01:40 AM
tornado_735's Avatar
I'm curious about this as well, but I would suspect it's a straight flush and fill. There aren't any clutches to burn up like in an autobox.
Old Aug 3, 2010 | 07:14 AM
antichrist's Avatar
I just drained the ATF and put in the Redline. No flush needed.
If you want to be compulsive you can drain the cooler lines also.
Dambo416
Feb 6, 2011 03:51 PM
BajaXJ92
Feb 6, 2011 11:12 AM
losinov
Dec 27, 2010 10:00 PM
turtle97tj
Mar 23, 2010 04:36 PM
brokenclassic
Mar 15, 2006 12:49 PM
