Attempting to reset and correct RPM (LRD1)
Old Apr 23, 2011 | 11:54 AM
LRD2&ME's Avatar
From: Oklahoma; where the winds come rolling down the plains.
Default Attempting to reset and correct RPM (LRD1)
Last week I mentioned I had completly disassembled my Throttle Body intake manifold for cleaning and malfunction check.. In doing this I had removed and cleaned everything and then re-assembled. I have followed The Rave examples to reset the kickdown cable and the throttle cable. Here is what happened. First I recalibrated my throttle plate to the fully closed position. Next I adjusted the kickdown cable to the specified measurements found in CH.44, Pg 1. This reference chapter and page describes turning the throttle cable knurled plug until the kickdown cable crimped nipple is 1mm away from the threads. Here are the results. The throttle body was moved to a 70 degree angle when the knurled plug was rotated to the Rave adjustment. Upon engine startup this 70 degree angle caused the rpm's to increase rappidly (way out of range). Has anyone else tried this procedure? I'm sure that I followed it exactly. Help Please!
Old Apr 23, 2011 | 12:29 PM
LRD2&ME's Avatar
So now I have found an area in Rave that contradicts itself. Chapter 19, page 15, sentence # 45 says to allign the throttle cable with the lever. Sentence # 46 says to allign the kickdown cable with the lever. I'm sure I have the SFI and I'm in the right area for the 4.0L. And I have an automatic transmission, so I'm using chapter 44 ZF as a reference for the kickdown cable adjustment. Does anyone see any errors with this? What example should I be following here?
Old Apr 23, 2011 | 01:00 PM
LRD2&ME's Avatar
Just went back out and tried Chapter 19 page #15, sentence #45 & #46. This seems right for the 4.0L. However Using a digital tachometer, I still cannot get the RPM's below 780's. I wonder why Chapter 44 pg 1. says to adjust the kickdown and throttle cable that way? Chapter 44 page 1 must be a write up for the 3.9L.
Old Apr 23, 2011 | 02:19 PM
Spencerfitch's Avatar
I'm lost as fk as to what your trying to really do but.. Engine usually idles higher when cold
D1V8OZ
Feb 8, 2015 07:50 AM
LRD2&ME
May 2, 2011 11:25 AM
LRD2&ME
Apr 26, 2011 11:05 AM
LRD2&ME
Apr 19, 2011 10:54 AM
Classklown90
May 2, 2010 09:34 PM
