Attention!: Stabbing holes in your radiator releases frustration
Old Dec 24, 2010 | 03:55 PM
Spencerfitch's Avatar
Default Attention!: Stabbing holes in your radiator releases frustration
Well finally got my water pump done..
Took me WAY longer than I expected. I was getting quite pissed at the stupid fan clutch [never did one] then I was trying to take the belt off and the wrench I was using kept hitting the peice the fan shroud attaches to. I couldn't get my wrench off and got pretty pissed and started beating it with a screw driver. I broke the stupid peice off [not needed] and I felt happy to vent all that frustration.
Finished water pump and went to fill up with coolant and noticed a steady drip, followed by noticing a huge hole I punched through my radiator. There goes my tire money... AGIAN.. I would be pissed but my radiator already had a slight leak and was going to be replaced before summer anyways..
Now I need a radiator.. Good Source?
Old Dec 25, 2010 | 11:45 AM
Mtouring_tuff*typing's Avatar
Ouch!! i did that with a volvo years ago, Time for a Junk yard run.
Old Dec 25, 2010 | 12:37 PM
There only 28$ at the junkyard. Saddly the junkyard is all out of
Discoveries. I would buy a peplums
But roversnorth nolonger carries them. Im either gonna call Monday and ask about a recore or buy new for 480-580$
Old Dec 26, 2010 | 06:28 PM
bmxermike's Avatar
My water pump went today, putting the new one in tonight, hopefully it goes in a little easier than yours.
Old Dec 26, 2010 | 08:58 PM
I can remove clutch in 10 seconds now. Using two channel locks.
First time you have to use a hammer though. You can push all you want it won't break. A little penetrant and a hammer came right off now it's easy peasy
Old Dec 27, 2010 | 01:55 AM
bmxermike's Avatar
So 4 hours later...
My fan clutch wouldn't come off so I just took the water pump off, that was a pain getting to all of the bolts with the fan in the way. Then I put the water pump in a vice and could get the clutch off. Installing everything there was easy, used anti seize on the fan clutch so hopefully it comes off next time.
carid
Appearance & Camping Set Ups
Jan 9, 2015 04:22 AM
arnottdoug
Member Group And Special Buys
Dec 22, 2014 08:07 AM
arnottdoug
Dec 22, 2014 08:04 AM
arnottdoug
Jul 3, 2014 08:55 PM
honda50r
Off Topic
Oct 22, 2012 11:42 AM
