Auto Transfer case to manual trans
I have a 94 Disco 1 with a manual trans, The transfer case went out do to poor driver skills ( lol DD couldn't drive a stick ) i found a transfer case of an 01 disco can i marriage the two?
Okay so here is what I think the misinformation is..
The transmission is: your gears 1,2,3,4,5 whatever plus Reverse
The transfer case is: you hi, low, hi-locked, low-locked settings for off roading, etc..
Interesting, good questions posed. OP, also I have a transfer case out of a 94 D1 spare if interested, (or even needed) will have the CDL linkage etc.
If you were switching from high/low range or engaging the CDL maybe you didn't get it quite re-engaged, they can be a bit stubborn, thus giving the illusion of a transfer case problem. I find doing it on a slight uphill slope if possible helps so you can let the truck roll back a bit until the transfer case locks into gear properly.
FYI- From what I can see in the manual the STD & Auto transfer cases LOOK the same, but that doesn't mean they are, I've never done a side by side comparison. And I'm only looking at a manual (book) for a D1. It's quite possible the D2 drivetrain may have slight differences, especially on the BMW powered ones. (I'm actually hoping one day to put the 4.4 BMW in my 5spd D1, with a 6spd Getrag out of a 5 series).
smoker
Oct 30, 2012 07:08 PM
wheelgarage
Feb 23, 2012 10:20 AM
oscevans
Dec 31, 2011 03:05 PM
csb
Jul 23, 2009 08:57 AM
