Auto vs Manual centre console?
Old 05-06-2016 | 10:11 AM
archaeology_student's Avatar
Default Auto vs Manual centre console?
Is the centre console on the auto interchangeable with the manual? Would the auto shifter hole be the same size for the manual shifter boot?
Someone cracked and broke my window switch covers as well as the e-brake console plastic
Old 05-06-2016 | 01:05 PM
ihscouts's Avatar
Believe there is no difference.
Old 05-07-2016 | 08:56 AM
Paul Grant's Avatar
The cutout for the five speed transmission shift lever is almost square where as the one for the automatic is significantly longer.
Old 05-07-2016 | 02:07 PM
That's what I was afraid of
Does anyone have experience or recommendations with plastic welding or some type of material to bond plastic?
The e-brake plastic is cracked as are the covers for the window switches
Old 05-26-2016 | 04:04 PM
expeditionnw's Avatar
I used an auto console when I built a manual truck. I filled in the extra space with some scrap ABS. Ill save you a ton of hassle by telling you theres no resin that holds it. best to rivet a support underneath the hole and then resin it. the rubber pad on top will hide a lot.
kbforn
04-15-2013 09:13 PM
Halfshaft
08-05-2012 05:01 PM
Timdawg
02-14-2011 08:23 AM
ajh
01-06-2007 07:30 PM
ray_hyland
06-03-2005 05:12 AM
Quick Reply: Auto vs Manual centre console?
