Back passenger window will not go down
Old Apr 4, 2012 | 04:41 PM
Nessa767's Avatar
Default Back passenger window will not go down
When I bought my land rover I was told the back window don't go down before I purchased it. I thought it was just possibly the fuse. I tried it and it wasn't. When you press the buttons for the windows there's no sound at all that's why I thought maybe a fuse. I had a Honda it's sunroof didn't work so I replaced the fuse and it worked! Not the case here. I was thinking possibly the motor?
Old Apr 4, 2012 | 04:56 PM
filbs's Avatar
is it both back windows? if so check the tech section for a solution. it may be the easiest fix of your life... it was for me a cold solder had popped and needed to be fixed
Old Apr 4, 2012 | 05:08 PM
Nessa767's Avatar
Yes, it's both. Thanks! I'll check there.
Old Apr 4, 2012 | 05:19 PM
filbs's Avatar
I couldnt find the sticky but here is the site i used
"Repair a Land Rover Discovery electric window ECU to make the rear windows open again"
Old Apr 4, 2012 | 05:33 PM
Nessa767's Avatar
Thanks! I will try this
Old Apr 4, 2012 | 09:14 PM
jeff spahn's Avatar
That repair is on my to do list, right after the steering . . the window regulator . . the subwoofer refoam, the hood and roof paint. . . the lug nut cap replacement.
Old Apr 4, 2012 | 10:02 PM
ColoDisco's Avatar
Thanks for the link! Mine have been acting up.
Old Apr 4, 2012 | 10:10 PM
filbs's Avatar
glad I was finally able to contribute something lol
Old Apr 5, 2012 | 06:52 AM
slanginsanjuan's Avatar
just dont buy the AB kit.
Old Apr 5, 2012 | 06:54 AM
i hear ya brotha.
if the lugs are bad, do them first tho. if availability or cash is an issue..do the fix in the sticky. people are getting stuck with those lugs.
