Back up lights
Old Feb 8, 2011 | 12:24 PM
jbriggs's Avatar
Default Back up lights
5 speed manual transmission. I have to hold my shift lever to the right to get the reverse lights to come on. The clutch was changed by a local indy shop many years ago and I think they may have messed up the adjustment. Has anyone ever adjusted theirs? Is it easier to pull the center console to get to the switch? Thanks.
Old Feb 8, 2011 | 06:04 PM
Man I have no idea.
Old Feb 9, 2011 | 11:12 AM
Chris-bob's Avatar
I have the exact condition on mine as well. I just assumed I needed to crawl under and adjust the switch.
Old Feb 9, 2011 | 12:00 PM
COOTER-GUY's Avatar
I am just guessing but the switch is most likely a spring loaded ball type that is screwed into the side of the transmission, that is typical to the style used on Gm and fords as well
Old Feb 9, 2011 | 12:17 PM
jbriggs's Avatar
I haven't been able to find the switch and was hoping someone could describe exactly where it is. The RAVE doesnt have a good picture of it. I also looked on ALLDATA and it has a similar picture which isn't like thae actual transmission.
Old Feb 9, 2011 | 12:31 PM
COOTER-GUY's Avatar
Go to gearbox in the rave, page 19 it is item #23 passenger side of the case behind the starter. Definitely spring loaded with a ball
Old Feb 9, 2011 | 03:05 PM
jbriggs's Avatar
I was looking on the wrong side. Thanks!I
Externet
Nov 23, 2013 03:28 PM
twaszak
Dec 28, 2012 01:11 AM
attackRus
Feb 22, 2012 04:35 AM
sito007
Oct 2, 2011 07:17 PM
