Bad fuel pump?
#31
It is def something to do with the ecu. I started taking one of the bolts off then dropped my wrench. I did tap the ecu as well. I tried starting it instead of looking for the wrench. It drove perfect!!!
Could it be possible that it took a couple of times starting the truck for the truck to recognize the new fuel pump?
#32
I do not know of anything that has to "Recognize the new fuel pump?" Sounds like you are grasping for straws, please don't create possibilities that have no basis.
It would not be unheard of for a newly installed exhaust to have some type of problem. Or something else that was involved in the recent repairs. Did you replace the front O2 sensors or did they reinstall the existing ones?
Often times the latest repairs or mods do cause or contribute if not directly cause a new or different problem.
#33
Danny - the pump was replaced without the battery disconnected. It was my understanding that the ECU/M "reset" when this occurs. (battery disconnected for 30+ minutes) Therefore, if he put a new pump in, and the ECU/M had NOT "reset" then it would have been attempting to run with the mixtures from the bad pump.
Once the unit "reset" then it would have read the pressure etc...from the new pump and ran correctly.
Is that not the case?
#34
#36
Hmmm, I know the ECM does not monitor fuel pressure. I do not know if the ECM would or could adjust the mixture based on a dieing pump...I had never considered it before. Wouldn't surprise me on a Land Rover if it did. But a few drive cycles would/should clear that up with it's adaptive memory.
#37
That was my thought - and seems to be what he is experiencing...it was "same/same" for the first couple runs, then - after his incident with the Fuel ECU - it cleared up and is now running well.
There still may be an issue with his ECU as prior to replacing the pump he had intermittent success by "jiggling" the wires.
Any idea if the fuel ECU is subject to the same "breaks" as the rear window ECU's? Because I think that may be the issue...
#38
I highly doubt it has anything to do with the exhaust. I was having this problem before the exhaust was installed.
I have yet to try and drive the Rover again today. Knowing my luck the problem will be back.
#39
You did not tell us that! We can't read your mind.
I know that the ECU sends the power to fuel pump but unaware of the ECU monitoring fuel pressure if it does indeed occcur. It does monitor temp and adjust accordingly.
If he can jiggle wires or bump the unit and get a change, that is highly indicative of an electrical issue. I have read that the Engine ECU and Window ECU do indeed share those characteristics of bad solder joints. I have also had bad in-line splices and damaged or degraded insulation cause problems on my Discovery.
Travelor
09-24-2015 06:11 PM
JumPeR04
04-07-2011 09:52 PM
