Base idle setting
Old Jan 26, 2015 | 06:07 AM
Kobus van Eeden's Avatar
Default Base idle setting
I have a disco 1 96 v8i, my problem is that I can not set the base idle when I disconnect the air bypass hose the idling goes up and down short intervals and then eventually die out what can be the problem. thx
Old Jan 26, 2015 | 06:07 PM
TOM R's Avatar
Codes?
Check pcv hoses, clean pcv noodle, clean throttle body, clean IACV
Old Jan 27, 2015 | 10:05 AM
MonteroMan's Avatar
Talking Ja Swaer....
Kobus stuur my 'n PM.
Old Jan 27, 2015 | 10:22 AM
USNAVYORDNANCE's Avatar
Check what Tom said. My rig had the same issue when I first got her and replaced all the vacuum lines then clean sensors. Idles as it should now.
Old Jan 29, 2015 | 07:55 AM
Wat is PM lol
Old Jan 29, 2015 | 07:58 AM
Originally Posted by TOM R
Codes?
Hi Tom
THX for the information I have done all of what you said and still not right
Old Jan 29, 2015 | 09:45 AM
jafir's Avatar
You have to blank off the ports after you remove the bypass hose or else you'll just get a vacuum leak.
Old Jan 29, 2015 | 11:20 AM
Attachment 24478
Hi Jafir
When I blank it off she does not want to start, thx
Old Jan 29, 2015 | 11:30 AM
MonteroMan's Avatar
Wat is PM lol
Wys jou hoe gou leer mens swak taalgebruik aan... ek kon dit seker baie beter gestel het
Wou sommer net kontak maak en het bedoel jy moet 'n boodskap op die "personal message" fasiliteit stuur.
Andries
Old Jan 29, 2015 | 11:32 AM
TOM R's Avatar
do you have a scanner that shows live data? if so what is the tps with key on?
